Hello,
This is before my time, but can somoene tell me the differences between the DC8 and the Boeing 707?
Anyone got numbers or a guess on how many are still in operation?
Captain
Difference between DC8 and a B707 ?
both were produced for the medium to long range pax and cargo jetservices. The DC8 came a bit later on the market (both in the fifties). The DC8 has a slightly larger fuselage cross-section and is "slightly" heavier.
Here some brief numbers
B707/B720
Build: 1013 (with 95 "AWACS"),
version 020 or B720 (short body medium range): 154 build
version 120 (medium range): 141 build
version 320 (long range): 69 build
version 320B (improved for long rang): 188 build
version 320C (improved for long range and convertible): 336 build
version 420: (long range with Rolls Royce engines iso PW): 37 build
Current number in civil use: around 40. Stage III noise limits meant the end of 707 operations in Europe and USA since 2002.
Current AWACS in service: 91.
The tanker version was named "KC135" of which 820 were build and around 600 remain in service.
DC8
Build 556
version 10 (medium range): 28 build
version 20 (longe range with improved engines): 34 build
version 30 (longe range with improved engines): 57 build
version 40 (long range with Rolls Royce engines iso PW): 32 build
version 50 (long range with improved engines): 141 build
version 61 (stretched medium range): 88 build
version 62 (slightly stretched long range): 68 build
version 63 (stretched long range): 107 build
version 70 (reengined): around 100 were converted with CFM turbofans
No military version and around 140 remain in civil (most cargo) use.
Hope this is of help. I suggest to surf a bit on the internet as "books " can be told on both frames.
Brgrds S
B707/B720
DC8
Build 556
Brgrds S
Fasten seat belts.....
Look at this guy surfing (?) on a DC8...
To read more about DC8's goto dc8.org (includes movies)
And the DC-8 Skybus never made to the skies:When the DC-8 designation was finally applied to a production aircraft, it was used on the swept-wing jet that we are all familiar with. About the only thing common to the first and final configurations of the DC-8 was application of air intake scoops on each side of the nose. The clean, unencumbered wing design of the Skybus finally appeared on the DC-9.
btw, No examples of the DC-8 Skybus were ever built. See also The DC-8 Skybus Proposal
A art job for our MD11?
Correct, and this is an high frequency antenna. But not all B707/720 did have this antenna. Check for example the picturesof the United B720s, and pictures of American Airlines B707s.jan_olieslagers wrote:an eye-catcher on a B707 is the (antenna? pitot intake?) sticking out forward on top of the tail fin
Brgrds S
If I remember well, the DC8 was not starting its engines the same way a 707 did; The boy I was remembers a DC8 engine would start with a big sound burst and with ground assistance (and some pollution) whereas the 707 engines would start more smoothly (and without ground assistance am I right ??)
Greetz
Christophe
Greetz
Christophe
