BRU 22/05/2018
Share pictures, log-reports, special aircraft, nice events, hints and tips from the Belgian airports
Marcoz
BRU 22/05/2018
Post by Marcoz »
sta 07:55 F100 OM-BYC SSG004 from LZIB
sta 08:45 LJ45 IRL258 from EIME
sta 10:58 B461 ZE700 RRR1922 from EGWU
std 11:45 C560 70-105 DUKE87 to ETOU
std 13:15 B461 ZE700 RRR1922 to LIRE
sta 15:15 GL5T 14+04 GAF614 from EDDK
std 16:30 GL5T 14+04 GAF614 to EDDT
std 17:15 F100 OM-BYC SSG004 LZIB
std 17:15 LJ45 IRL258 to EIME
tangolima
BRU 22/05/2018
Post by tangolima »
1550-xxxx E190 OONGI
xxxx-1555 IRL LJ45
xxxx-1615 GALX OEHAS
1620-xxxx BE20 MSPOR
xxxx-1620 F900 MILTA
xxxx-1630 GAF GL5T 1404
xxxx-1640 C56X CSDXO
xxxx-1705 RRR B461 ZE701
xxxx-1715 GLF5 N546QS
xxxx-1715 SSG F100 OMBYC
1730-xxxx C68A CSLTF
1735-xxxx GLF6 MAAAL
xxxx-1745 C25B FGSCR
xxxx-1745 F900 N5MV
1800-1830 GLEX ECMKH
xxxx-1835 C650 HAJEV
xxxx-1835 GLF5 N785QS
2015-xxxx C56X GXSTV
2240-xxxx GLF6 ECMHZ
2320-xxxx GLF6 N82A
ALL TIMES LOCAL
Greetings,
sdbelgium
Re: BRU 22/05/2018
Post by sdbelgium »
0810 ACA A333 CGHLM *A
0810 DLH E190 IADJL
0825 CSA B737 OKSWT
0840 ADR A319 S5AAR
0840 CTN A319 9ACTI
0855 SWR BCS3 HBJCJ
0900 BTI BCS3 YLCSG
0950 KLM B738 PHBXA
1100 IRQ A320 EPFQR
1115 IBE A319 ECKHM
1405 JAF B738 CSTQU
1655 AUA A320 OELBT
1720 SAS A20N SEROA
1820 DLH A20N DAINH
1840 LOT B738 SPLWC
1910 CSA B38M OKSWC
1930 SWR A320 HBIJN
1935 TAP A320 FHBIS
1945 CTN CRJX ECLJT
2005 SAS A20N SEROB
2020 DLH A20N DAINC
2115 ASL B734 EISTL
2215 JAF A320 SXSOF
Re: BRU 22/05/2018
Expect delays, Lightning procedures now in progress.
Re: BRU 22/05/2018
AarjenP
Re: BRU 22/05/2018
Post by AarjenP »
Hello,
Question about an aircraft I saw yesterday on the tarmac at 18:23. Is this the ZE700 RRR1922 mentioned in the 1st post? Because the std is mentioned at 13:15 there, so I'm not shure if this is the one.
I did not had my tele lens with me due to the bad weather, so It's only a photo from a major distance:
Thanks!
Re: BRU 22/05/2018
It is/was. It had a technical problem and stayed overnight on the Abelag Apron. It departed again at about 0900z on 23/05.
AarjenP
Re: BRU 22/05/2018
Post by AarjenP »
KriVa wrote: 23 May 2018, 12:41 It is/was. It had a technical problem and stayed overnight on the Abelag Apron. It departed again at about 0900z on 23/05.
Thank you!
Established02
Re: BRU 22/05/2018
Post by Established02 »
This is ZE701 at 18h55. With technical problems as well?
AarjenP
Re: BRU 22/05/2018
Post by AarjenP »
Established02 wrote: 23 May 2018, 14:48 This is ZE701 at 18h55. With technical problems as well?
Ah yes, It is the 701 that came yesterday. So my picture, the plane with the technical problems and your picture are all the same aircraft: the 701 :)
The 700 came for a visit last week.
