Diversions from around the globe (medical, technical, ...) 2017
Re: Diversions from around the globe (medical, technical, ...) 2017
Air Berlin flight AB8585 (A320 reg. D-ABFN) from Zurich to Dusseldorf diverted to Stuttgart.
MNG Airlines flight MB751 (Airbus A300-600 reg. TC-MCH) from Doha to Istanbul is squawking 7700 and diverting to Manama (Bahrein).
EasyJet Switzerland flight U2 1454 (A319 reg. HB-JYJ) from Porto to Geneva is squawking 7700 and diverting to... Clermont- Ferrand?
sn26567 wrote: 07 Oct 2017, 10:40 EasyJet Switzerland flight U2 1454 (A319 reg. HB-JYJ) from Porto to Geneva is squawking 7700 and diverting to... Clermont- Ferrand?
The crew decided to divert to Clermont-Ferrand reporting smoke in the cockpit. During the descent, the smoke ceased.
The aircraft landed safely on Clermont-Ferrand's runway 26 about 30 minutes later. Emergency services did not find any fire or heat or another possible source of the smoke.
The passengers were bussed to Geneva.
https://avherald.com/h?article=4af6e185&opt=0
Air France is not lucky with its A380s these days:
Air France flight #AF84 (A380-800 reg. F-HPJG) is on its way to SFO after an earlier diversion to Montreal due to a medical emergency.
Post by quixoticguide »
Air Canada #AC880 to Paris returning to #Toronto
Emergency services dispatched
Boeing 777-300
https://fr24.com/ACA880/f279831
A Lufthansa A380 registered D-AIMM from Frankfurt to Houston returned to Frankfurt after gear issue. The aircraft is scheduled for this evening flight to Hong Kong.
Lufthansa flight LH936 (E190 reg. D-AECG) from Frankfurt to London City returned to Frankfurt after a sightseeing tour above Belgium and The Netherlands.
Another one diverts to Goose Bay: Air Canada flight #AC859 from London to Toronto (Boeing 787-9 reg. C-FKSV), probably due to the needs of a passenger. The diversion is not expected to last long.
Ryanair flight #FR6622 to Edinburgh (Boeing 737-800 reg. EI-EBK) had to return to Tenerife South tonight after a passenger suffered a heart attack. Couldn't it have landed in Funchal instead?
Auka
Post by Auka »
Just seen, Brussels airlines flight BRU-DLA #SN371 diverted 1 hour ago to PMI
A problem on OO-SFY ?
https://www.flightradar24.com/data/airc ... fy#f2e207a
Auka wrote: 12 Oct 2017, 16:26 Just seen, Brussels airlines flight BRU-DLA #SN371 diverted 1 hour ago to PMI
And again enroute to Douala, after about 1,5h on the ground at Palma de Mallorca. Therefore my guess: medical issue.
https://www.flightradar24.com/data/aircraft/oo-sfy
Aer Lingus flight EI845 (A320 reg. EI-DEM) from Amsterdam to Cork diverted to Cardiff. Reason unknown.
sn26567 wrote: 29 Sep 2017, 10:11 easyJet flight U22952 (A320 reg.G-EZOC) from Mykonos to Milan Malpensa is squawking 7700 and diverting to Athens.
The crew noticed an odour and subsequently smoke in the cockpit obviously originating from underneath the first officer's rudder pedals. The crew declared emergency and diverted to Athens where the aircraft landed safely on runway 03L about 30 minutes later.
Greece's AAIASB rated the occurrence a serious incident and opened an investigation. The odour and smoke originated from the electronics compartment underneath first officer's rudder pedals.
The occurrence aircraft remained on the ground in Athens until Oct 1st 2017, then positioned to Milan Malpensa and resumed service on Oct 2nd 2017 about 70 hours after landing in Athens.
Source: https://avherald.com/h?article=4af9915a&opt=0
sn26567 wrote: 12 Oct 2017, 22:39 Aer Lingus flight EI845 (A320 reg. EI-DEM) from Amsterdam to Cork diverted to Cardiff. Reason unknown.
And now the reason is known: smoke in the cockpit.
A replacement A320-200 registration EI-DEG picked up the passengers in Cardiff and reached Cork with a delay of 4 hours.
sn26567 wrote: 10 Oct 2017, 22:47 Lufthansa flight LH936 (E190 reg. D-AECG) from Frankfurt to London City returned to Frankfurt after a sightseeing tour above Belgium and The Netherlands.
It was a "serious" hydraulic problem:
http://avherald.com/h?article=4afb0e59&opt=0
Aigle Azur flight #ZI321 to Faro (A320 reg. F-HAQD) just returned to Paris ORY after declaring an emergency.
Icelandair flight FI532 from Reykjavik to Munich (B757-200 reg. TF-FIR, the famous 80 years of aviation livery) diverted to Glasgow. Probably medical, because it is again on its way to Munich.
20th October - Malaysia Airlines MH-1 London-Kuala Lumpur:
http://avherald.com/h?article=4affe0cc&opt=0
Passenger wrote: 21 Oct 2017, 20:56 20th October - Malaysia Airlines MH-1 London-Kuala Lumpur:
The Aviation Herald nicely calls this incident "Loo woes" :)
A Malaysia Airbus A380-800, registration 9M-MND performing flight MH-1 from London Heathrow,EN (UK) to Kuala Lumpur (Malaysia), was en route at FL330 about 5nm south of Brussels (Belgium) when the crew decided to turn back to London due to the lavatories becoming inoperative due to lack of water. The aircraft dumped fuel and landed safely back in London about 75 minutes later.
Dumping fuel when there is a lack of water? Couldn't some fuel be used to flush the lavs? :)
